Will amd ryzen 2400g APU be enough for running dota 2 without gpu
rajuplays
39
My total budget is around 680$, but today i found out that razen 2400g is good apu for 150$.
Can u guys suggest me other stuff along with it (motherboard, psu(my current one is 220v), ram(current one is 4gb ddr3 ram), i have a medium sized cabinet idk how to check its size according to standards( its bit smaller than my old intel pc cabinet).
What i want is a pc for 2-3 years of dota 2. I play long hrs 7-8hrs continously so pls also suggest cooling solutions .
My current rig is amd apu 4-4000, 3.2ghz and a intregated graphic card. It used to work decent for dota 2 until last year now it drops fps to 20-30 and i cant even listen songs when i play dota 2. If i install a dedicated graphic card with this rig will it work for 1-2 years? Also i think my hard drive may be slow now game and files load slow now a days.
Not sure of your location, but this would be a decent build. The 2400g will run Dota just fine. It is a good option for esports. I would suggest getting 3200mhz RAM, and you may want to go with 16gb as the APU will does not have dedicated VRAM. It will use the system resources. Wont be much of an issue for Dota, but other games may give it problems.
PCPartPicker part list: https://pcpartpicker.com/list/WtJHQZ
Price breakdown by merchant: https://pcpartpicker.com/list/WtJHQZ/by_merchant/
CPU: AMD - Ryzen 5 2400G 3.6 GHz Quad-Core Processor ($158.89 @ OutletPC)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard ($54.99 @ Newegg)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory ($129.99 @ Amazon)...
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive ($82.89 @ OutletPC)
Power Supply: SeaSonic - S12II 520 W 80+ Bronze Certified ATX Power Supply ($34.40 @ Newegg)
Total: $461.16
Generated by PCPartPicker 2018-11-11 14:01 EST-0500
It should be more than able to handle DOTA 2. You might want to wait a bit and see if AMD ever releases something more powerful along the lines of the Fenghuang APU because that would be ideal, not sure what's keeping AMD from doing so, maybe it's a CES release thingy?
