will amd wraith cooler definitely fit ?
KyleRaino
Commendable
Nov 7, 2016
191
i am using their old cooler on a amd a6 6400k and on Gigabyte GA-F2A88XM-DS2 Micro ATX, if the motherboard is fm2+ will it definitely fit okay ? or will it intrude on ram slots etc
They're close to the cooler, but not to the socket. You have to consider that your cooler overhangs the socket by quite a bit. If you took the cooler off, you'd find that there's plenty of space between the socket and the RAM slots.
I agree. You should be fine. AMD wouldn't design a cooler to not work on all similar products of the same TDP... It wouldn't make sense.
https://imgur.com/wfIpzAz the ram slots seem very close to the cpu cooler don't you think? And the wraith seems huge in comparison to my cooler now
