[SOLVED] Will AMD wrath prism cooler fit my a320m pro e mobo?
Dowell71
Commendable
Sep 14, 2019
57
so im getting a wraith prism cooler for my pc, i dont now if it will fit in without interfering the ram
PARTS
RAM: GSKILL TRIDENT Z RGB 16GB
MOBO: MSI A320M PRO E
CPU COOLER: AMD wraith prism cooler AM4
wraith prism cooler is a stock cooler for ryzen cpus
Any of the Wraith coolers will work on AM2/AM3/FM2+ and AM4 since they all use the same Clip mounting, there is a little difference in bracket highest so you want to use the mounting hardware that comes with the cooler.
These are the active connectors.
  • 1 x 24-pin ATX main power connector
  • 1 x 8-pin ATX 12V power connector
  • 4 x SATA 6Gb/s connectors
  • 2 x USB 2.0 connectors (supports additional 4 USB 2.0 ports)
  • 1 x USB 3.1 Gen1 connector (supports additional 2 USB 3.1 Gen1 ports)
  • 1 x 4-pin CPU fan connector
  • 1 x 4-pin system fan connector
  • 1 x Front panel audio connector
  • 2 x Front panel connectors
  • 1 x TPM module connector
  • 1 x Chassis Intrusion connector
  • 1 x Serial port connector
  • 1 x Clear CMOS jumper
None of those A320 Pro boards have RGB headers, you will need a controller via USB to use the RGB effects. Mystic software though will integrate with anything you uses fairly well.
