[SOLVED] will an 6 pin to 8 pin adapter work for aorus gtx 1060 ?
What is the male/model of your psu?
If you have a quality psu in the 500w range, you should be ok to use a 6 pin to 8 pin adapter for your GTX1060.
Repeat... QUALITY.
Most such modern psu's will have two 6+2 pin pcie leads and you need to use only one of them.
Sebastian_19
Commendable
May 24, 2016
18
The psu is https://www.morele.net/zasilacz-akyga-550w-ak-b1-550-635304/
Akyga 550W ( It's not from a very known company (such as nzxt, coolermaster, corsair .. )
It has an PCI-E 6-pin cable
