Will an AM3 processor work in an AM3+ Motherboard?
MentalTiger
30
Hi guys,
I am buying a gaming PC, and I have seen that, on AMD's side of things, that a Phenom would be best for gaming.
However, I was previously going to get an AM3+ processor, but the Phenom is AM3.
My question is this: I am considering buying a AMD Phenom II X4 965, which is AM3 socket, and an Asus M5A78L-M/USB3 AM3+ motherboard. Will the Phenom still be usable on this motherboard?
It may be a dumb question, but I want to be sure before buying.
Also, if you have any tips about the Phenom or an alternative (though I'm pretty sure I'll be sticking with this one), tell me please!
Thanks!
Fair enough XD
Do you use the Phenom?
DERP just read it again XD sorry for the stupidity.
You are mistaking Phenom for Phenom II. Phenom I AM2+ whereas Phenom II is AM3.
AM3 CPUs should work in AM3+ socket motherboards. I've heard a few unconfirmed reports of issues, but I've never seen any myself and chances are that those reports were just due to faulty hardware rather than incompatibilities and even if they were incompatibilities, it would have merely been BIOS defects.
However, anyone telling you that you're better off going for a Phenom II x4 such as the 965 instead of getting a newer model such as the FX-4300 is wrong. You'll get similar if not better performance while using much less power and having more overclocking headroom. Oh, and a similarly priced FX-6100 can have an advantage in a few of the most intensive DX11 games such as Crysis 3 that can scale across the extra cores, granted it has a disadvantage in games that don't scale so well (the newer FX-6300 has no such disadvantage, but it's a little more expensive).
Hmm. I was told that the Phenom would be better, but I'm not too sure now. Is the FX AM3 or AM3+?
So the FX-6100 has 6 cores, but a lower clock speed. I am still being turned to the Phenom, mind you. I played AC3 and NFS most wanted on it before, with the same graphics card I will get, and it was staggeringly good.
FX is all AM3+ at this time. That includes both Bulldozer/Zambezi models (FX-41xx/42xx series, 61xx/62xx series, and 81xx/82xx series) and the newer Piledriver models (FX-43xx series, FX-63xx series, and FX-83xx series).
Per core, Phenom II was better than FX-x1xx/x2xx CPUs of similar or even somewhat higher clock frequencies, but the FX-x3xx models have caught up and at times surpassed the older AM3 CPUs, especially in overclocking.
Keep in mind that the main distinction between AM3 and AM3+ is that AM3 has DDR2 support whereas AM3+ lacks that, but has some power saving features and other additional features too. Their sockets are almost physically identical (AM3+ simply uses a few of the unused pins in AM3).
That may be so, but it really is more of a money saving exercise. I think it's now between the Phenom II and the FX6100.
Ok guys, I think I'm getting my head turned towards the Phenom II X4 965. I read reviews on both CPU's, the Phenom and the FX6100, but the Phenom just looks better. If anyone has any last words, speak them now!
It's a close call between the FX-6100 and the Phenom II x4 965. If you're interested in overclocking, the FX-6100 has the advantage, but if you're looking for the cheapest you can get with good performance, the Phenom II x4 965 is still a decent CPU. My own overclocked Phenom II x6 1090T BE is still holding up well.
Overall, the FX-6100 would only have an advantage when it comes to some of the more modern DX11 games such as BF3 MP, Crysis 3, Far Cry 3, and Metro 2033 where they can scale quite well across six cores. Otherwise, the Phenom II x4 965 will have the advantage unless you overclock or such.
actually is you check the cpu compatability list for the asus m4a89td pro/ usb3 it shows the fx am3+ cores being compatable on the beta bios.. ive thought about upin my cpue to the fx but don't want to spend the money if it wont work for me.. any input?
My input is that you should start your own thread, instead of necro one that was last posted in two years ago.
