Will an amp decrease background noise?
Lafar
Hi guys, I currently have Razer Kraken Pro headphones, and have them directly plugged into my Lenovo Y510p. I've always been hearing background noise like white noise, even when I have nothing playing, or if the volume is at mute/0. It isn't a problem with my headphones since if I change my audio to my monitor (I have a 3.5mm port on my monitor), and I plug my headphones into monitor, there is no white noise (Audio is running through HDMI cable to monitor to headphones).
My question is: Will an amp like the Fiio E6 reduce background/white noise? (If not, what will?)
Summary of above: Am hearing white noise if I plug headphones into laptop. Headphones are okay, the problem is not at headphones.
Thank you everyone!
Poor EMI shielding is the issue here. It is caused by electromagnetic interference when using an analog signal; ergo "white noise". Using a digital-to-analog converter should fix the problem. Certain manufacturers also offer audio drivers that may assist in filtering out background noise on analog devices. I would recommend buying a DAC instead.
