Will an Antec 1200 V3 be good enough to power 3 x EVGA GTX 570 in SLI?
While I don't disagree that getting a 1200 watt would be playing it safe, Tom's had no trouble at all testing 3-way SLI and XFire on an overclocked SB platform with a 1kw PSU: http://www.tomshardware.com/reviews/crossfire-sli-3-way-scaling,2865-2.html
When they benchmark using a certain setup I usually trust that it's rock-solid stable.
Depends on your motherboard. Which board do/will you have? The case should be fine, but if there isn't enough space between the slots, your cards will be hot and loud under load.
