Y yolor3stis Commendable Dec 9, 2017 25 0 1,540 Jan 20, 2019 #1 im building a pc soon would an Enermax ETS-T40 fit in corsair 275r ? (ram: corsair vengance rgb pro 3200mhz)
Solution Dark Lord of Tech Jan 20, 2019 Yes it will fit in the case: Case supports up to a 170mm cooler , the Enermax is only 160mm tall.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jan 20, 2019 Solution #2 Yes it will fit in the case: Case supports up to a 170mm cooler , the Enermax is only 160mm tall. Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Jan 23, 2019 #4 Glad to help! Upvote 0 Downvote
