Will an Essential Oil Diffuser Damage my PC components?
Wiltzz
79
My desk is where I spend most of my time, and want to have an essential oil diffuser on it... Unfortunately my PC is also on my desk, and because the diffuser uses water to function, I am afraid of it getting inside my case. I really want to have a diffuser on my desk, because I simply like the aroma it can give off. So, I want to ask y'all if I should pass on it or not. Here is a link to my case, https://www.amazon.com/gp/product/B00NGCS7YA/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1 Thanks!
Well problem only may occur if you use it non-stop like high moisture in air, soo it wouldn't be a problem only if your pc isn't watercooler, if its classical fans, then you can use it, but still i would check for moisture in case after a week, if there is no moisture after week then you can use it normally.
It will be about 3 feet away and to the side
Alright, thanks!
