[SOLVED] Will an Ethernet cable fix my high ping?
Jul 8, 2020
So for instance if im playing league about 2 meters from the router in the same room and i've got a ping that fluctuates from 500-1000 will an ethernet cable make a difference or will it just give me a stable 300 ping?
It should but that is assuming the problem is the wifi.
If you ping the IP address of the router and you see these large ping spikes then a ethernet cable should help.
This unfortunately is one of those things you need to actually test. It is extremely common for wifi to cause this but it can also be caused by over use of your internet connection. If some other devices in your house are using all the download or upload speeds you pay your ISP for you can get large delays also. That at least you can do something about by getting some agreement on usage or maybe buying a larger connection.
In general when things are working properly the ping is a measure of distance. The path though is not always direct so sometime the...
In general when things are working properly the ping is a measure of distance. The path though is not always direct so sometime the number is higher than you would like. It should be fairly stable number with only small variations.
