Will an i5 4440 fit in i3 550 motherboard?
Yashorton
28
I am looking to upgrade my computer. But I'm not sure if AN i5 4440 processor fit in an i3 550 motherboard. Can anyone tell me if this is possible?
No , that i5 CPU will not work in Your 1156 motherboard , You will need to buy a 1150 Motherboard!
Is there any other i5 processor that can fit my motherboard?
Almost forgot due new CPU is generating more heat you can encounter overheat problem on old CPU cooler , what CPU cooler you currently use ?
In addition, when replacing CPU you need clean CPU / CPU cooler surface * best are Coffe filers + Isopryl Alcholol 70% , 90%
or use http://www.ebay.com/itm/100pcs-Box-Alcohol-Pads-Preps-Wipes-Cleaning-Sterilization-70-Isopropyl-/151476467957?pt=LH_DefaultDomain_2&hash=item2344b378f5
Next when you insert and locked CPU in socket, latter apply thermal paste and install CPU cooler.
Step by step guide: http://www.pcstats.com/articleview.cfm?articleID=2731
Example CPU cooler compatible with your motherboard and thermal paste.
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($19.45 @ OutletPC)
Thermal Compound: Arctic Cooling MX4 4g Thermal Paste ($6.95 @ OutletPC)
