I am planning on upgrading a few components on my PC,
The CPU of choice is Intel i7-8700k *which says it supports DDR4-2666,
the motherboard I'm intending on using Asus ROG Strix Z390-E
*which supports DDR4 memory at speeds of:
Which is 4000 modules, knowing that in the motherboard BIOS i would have to enable XMP for it to run the RAM at 4000MHz.....the RAM is supported by motherboard, the speed intended is supported 4000(O.C.)
Both RAM and motherboard supports XMP*
If i was to use this configuration, Will the i7-8700k cap the RAMs speed to 2666MHz? *at which point i can choose to enable[or not] XMP to allow speeds like 4000MHz (or other supported O.C. speeds like 3400)
According to Intel, the i7-8700k is 'stable' at 2666MHz with memory...would it be better to leave the 4000MHz RAM capped at 2666MHz ?
I'm not terribly concerned with loss of 'MHz' from the RAM, considering 16GB at 2666MHz. No problem with leaving it capped at 2666MHz for longevity if it helps or not i dont know.
Will it work? Should i leave it capped if thats the case?
Thanks for your time.
- 4266(O.C.)/
- 4133(O.C.)/
- 4000(O.C.)/
- 3866(O.C.)/
- 3733(O.C.)/
- 3600(O.C.)/
- 3466(O.C.)/
- 3400(O.C.)/
- 3333(O.C.)/
- 3300(O.C.)/
- 3200(O.C.)/
- 3000(O.C.)/
- 2800(O.C.)/
- 2666/2400/2133 MHz
