Will an IFX-14 fit in a Lian Li PC-PC50R case?
cameron-lite
Hi guys,
Does anybody know if an IFX-14 will fit in a Lian Li PC-PC50R case? I'm fed up with leaving the side off my current case.
Case:
http://www.ebuyer.com/product/187421
IFX-14:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-069-TR
the Ifx-14 has dimensions of 146 x 124 x 161mm (L x W x H).
the Lian Li case has dimensions of 210mm x 495mm x 490 mm (W, H, D)
Excluding the heatsink, i have 49mm to spare for the case, mb etc.
I'd appreciate any help you can give me please, even if its just a 80% yes (or no).
Many Thanks,
Cameron
cameron-lite
Anybody got one or know somebody that does?
The distance from the motherboard tray to the side of the case would be perfect if anybody knows it.
Cheers
Cameron
