Question will an intel b75 work with a GTX 1650 OC
Dec 30, 2022
4
i have a intel b75 motherboard (what its called on system information) and it has a gt 710 . I'm thinking of upgrading to the gtx 1650 because it doesn't have external power connection but I don't know if it will fit . I'm struggling to find any information about this . my power supply is 500 w
Tac 25
Commendable
Jul 25, 2021
1,121
305
1,590
first of all, what PSU do you have? Having a proper power supply is important.
a 1650 would be a massive improvement over a GT 710. A 710 is not really for gaming.
about working on your mobo.. it probably depend on what brand of 1650. My Asus 1650 GDDR6 works just fine on older boards - using it for more than 3 years now with a Core2 Quad (it has an even older mobo than yours. lol). But I also heard some people having problem when they tried 1650 on older systems.
View: https://youtu.be/X101Nn-y8aQ
0:00 - CPU-Z to show Q9500, GPU-Z to show the 1650, and HWMonitor to show that temps are normal.
1:50 - Need for Speed
9:58 - King of Fighters XV
14:55 - Attacker-chan!
21:12 - DNF Duel
Tac 25
Commendable
Jul 25, 2021
1,121
305
1,590
here is my 1650. Have also tried it on a board that uses 2nd gen intel, and it also works there.
if you're going to buy, then I suggest getting exactly this brand.
also one more important thing. This gpu likes HDMI connection to the monitor. If your monitor does not have an hdmi port, then it might not display properly if you use adapters.
