Z ZF1940 Reputable Apr 3, 2014 7 0 4,510 Apr 15, 2014 #1 Hello, I was wondering if an intel core i5-4670K would be able to work with an ASUS P877-V ATX LGA1115 motherboard. If not, what intel CPU would you recommend? Here is my build list:http://pcpartpicker.com/p/3smuu
Solution B B BradleyJames Apr 15, 2014 it will not, a 4670k needs a socket 1150 motherboard, z87 chipset. any of the name brand motherboards are great, Asus, gigabyte, msi. cant go wrong
B BradleyJames Reputable Feb 18, 2014 421 0 4,960 Apr 15, 2014 Solution #2 it will not, a 4670k needs a socket 1150 motherboard, z87 chipset. any of the name brand motherboards are great, Asus, gigabyte, msi. cant go wrong Upvote 0 Downvote Solution
g-unit1111 Titan Moderator Jul 27, 2011 42,884 889 104,940 Apr 15, 2014 #3 No not compatible. The Intel Core i5-4670K uses socket Z87 where the previous generation i5-3570K uses socket LGA 1155. You would need a motherboard like this for the 4670K: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157369 Upvote 0 Downvote
