Will an Iomega ix2-200 work with 3TB HDDs
arunphilip
150
Hello,
I have an Iomega StorCenter ix2-200 NAS, set up in RAID-1 with 2 x 1TB disks. My NAS has been upgraded to the latest firmware (2.1.38.22294).
I want to know if I can swap in 2 x 3TB disks instead, for a capacity upgrade.
My concern stems from the fact that crossing the 2.2TB barrier for a boot drive has some requirements (UEFI, GPT) and I'm not sure if this is fulfilled by my NAS.
Anyone out there who's done this?
Note: I plan to do this upgrade only after the HDD prices have normalized, this is just for knowledge's sake.
Thank you.
I'd like to do the same on my StorCenter ix2-200. At the did you to it?
Do you have same advice?
Thanks.
Vincenzo
Hi folks
I just replaced my two 1TB original Seagate drives and installed 2 WD20EARX. I alsoupgraded my ix2-200 to 3.1.12.47838 firmware - the cloud edition one.
Right now I can see some error messages on dmesg:
sd 1:0:0:0: [sdb] Sector size 0 reported, assuming 512.
SAL (ERROR) 0 1 0 :Scsi command completed. pScb c858f340, ScsiStatus 2 completionStatus MV_SCSI_COMPLETION_BAD_SCSI_COMMAND
SAL (ERROR) CDB:12 1 0 0 ff 0
SAL (ERROR) Sense Data:72 5 24 0 0 0 0 c 0 0 0 0 0 0 0 0 0 0 0 0
but the RAID is rebuilding fine and I think some adjusts on /etc/hdparm.conf may solve it.
There are two adjusts that HAVE to be done: WDTLER and WDIDLE3 I think I'll need a desktop to run the WD utilities.
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 24
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 573
Info on WDTLER and WDIDLE3
http://blog.mikemccandless.com/2009/07/fixing-wd-gps-drives-with-wdtler-and.html
So far, so good
Regards, JLuiz
An update:
the Load_Cycle_Cound reached 1174 after 64 hours. I managed to install MAKE and GCC to compile idle3-tools and disabled WDIDLE3. The drives seems to be working fine until now.
TO install MAKE and GCC - Medium do high Unix skills necessary
http://ix2-200.wikidot.com/optware-installation
To install idle3-tools - Medium do high Unix skills necessary
http://idle3-tools.sourceforge.net/
Now I just need to disable WDTLER
Regards, JLuiz
