Question summary: I want to try to un-bend some socket pins on an LGA 1150 mobo, but I'm worried that if I don't get it sufficiently correct, and try to install the CPU, the CPU will be damaged. I've seen ads for an "New Laptop LGA-1150 LGA 1150 Fake Loading Board Test Card CPU Socket Tester" (https://www.amazon.com/Laptop-LGA-1150-Loading-Socket-Tester/dp/B072DZ5GGS), and they're very cheap. If I used such a tester and get a good result, would that make the CPU installation safe? Also, the ads I've found are for LGA 1150 laptops, but the mobo in question is for a desktop. Is that a deal-breaker?
Details:
I've just received a used ASUS Z87-A motherboard I ought on ebay. The ad insisted the board works perfectly (i.e, it was not sold as a non-working board to use for parts). However, there were a few bent pins on the board when I got it. I already owned the same board with bent pins that I sent back to ASUS for out-of-warranty repair. They wanted $130 to fix it (probably by replacing the socket). That price was utterly unacceptable, so I declined.
I bought it to replace a different Z87-A that worked perfectly for many years, but recently I found that I could no longer enter the BIOS and also that the system refuses to recognize any hard drive on some SATA ports (which I suppose could be a result of the same BIOS problem).
Will that tester help me prevent damage to my CPU if I don't get all the pins straightened well enough?
A zip file containing a bunch of photos -- an unchanged image coupled with one with circled bent pins -- can be downloaded here:
http://www.fileconvoy.com/dfl.php?id=g995060bd4058612b10000447631c7b9a34fb2dc36f
Thanks!
Details:
Thanks!
