I finally made it to Idiot First Class! I’m building a basic system for my Uncle, and instead of ordering the retail Processor in a Box, I accidentally added the OEM version to my cart. I have to have this built over the weekend, so there’s no time to order a replacement. (Actually, I’m doubly a moron because I actually checked over the order several times before placing it, and I usually look for OEM/white box for other components.)
The new processor is an AMD Athlon 64 X2 4200+ Windsor 2.2GHz, Socket AM2.
I have an original retail fan from an AMD Athlon 64 3700+, a Socket 939 CPU that sat in an Epox 9NPA+ Ultra. The rig was only used for about a year or so. I know I have to go to Radio Shack and pick up a bit of thermal compound, and it looks like it will fit, but I thought to ask just in case I’m headed for disaster. Is there anything else I should be aware of/know? Should I start calling around for new fans?
If it makes a difference, the new processor is going into an Asus M2N-VM DVI, and will be run completely stock (i.e., no OC).
Thanks!!!
Moronically yours,
Rhythm
Thanks!!!
Moronically yours,
Rhythm
