[SOLVED] Will an SSHD work on my motherboard?
That's not what it "supports", it's the options available from the factory.
An SSHD is a hybrid of an SSD and HDD (as the name would suggest) - and uses the same SATA interface of either an SSD or HDD.
So, yes, an SSHD is compatible with that system.
However, if you're already running an SSD + HDD setup, then an SSD is probably not worth it. SSHD's main benefit was in laptops, where storage space was limited & you couldn't have both the speed of an SSD and the capacity of an HDD.
If you have the ability to have a true SSD, that would be the preferred route to go.
Reactions: TJ Hooker
What drive are you looking at? That's just HP's own drives. Any drive that is proper type should work, regardless of capacity in most instances. I know years back, meaning 15 or so, HP was picky and only certain brand drives would work correctly in their systems. IBM did this too. Today though, this shouldn't be the case. Just recently fixed a cheap HP laptop by installing 500GB 860 EVO ssd, works fine.
Ok thanks
