Hello everyone,
I was just wondering if an Ultra / ChillTec / Socket 939/775/AM2 / Thermal Electric CPU Cooler would fit inside my XClio Windtunnel case on my MSI K9A2 Platinum motherboard? I have links below to refer to the items i mentioned above. They have the dimensions/measurements if that helps any.
Ultra ChillTec
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=2353734&csid=ITD&body=MAIN
MSI K9A2 Platinum
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130136
XClio Windtunnel
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103011&Tpk=XClio%20Windtunnel
I currently have a ZEROtherm BTF95 92mm cooler in my rig.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835887002
Thanks in advance
Ultra ChillTec
MSI K9A2 Platinum
XClio Windtunnel
Thanks in advance
