Question Will an Yenon RX 550 work with my pc?
Jul 27, 2021
My PC is a HP Slimline Desktop - 260-p030xt
Motherboard: Hamar 81B4
Processor: Intel Core I3 6100T 3.2Ghz
PSU: 180 W SFF Bronze internal power supply
You will need to find the length of the GPU (usually listed in the product specifications) and find or measure the available area in your case where the GPU will be placed to see if it will fit. Also, since you have a SFF (small form-factor) case, the GPU will need to come with a LP (Low Profile) bracket to fit the case.
Jul 27, 2021
It's 145MM In length.
--SID--
888
189
590
20
Yenon, you mean Yeston?
Is that RX 550 a Low Profile card?
Only a single slot card will fit because the 24 pin ATX socket is in the way for a dual slot card.
