Will any radeon 4890 model fit my gateway fx530 btx case
chronix112
I am wanting to upgrade my graphics card but i have no idea if it will fit my 16x slot contacting gateway has been next to useless so i thought i would try here. I have a gateway fx530 which uses the now dead btx case/motherboard.
Welcome to the forums!
It will not fit IMHO. You need a shorter card.
Dimensions: 260x100x33 mm (the last figure is the maximum thickness)
Make sure your power supply supports the card you want.
You can check back here on that.
