A arceus927 Reputable Aug 9, 2014 2 0 4,510 Aug 9, 2014 #1 Building a PC soon and i need to know. If it doesn't fit please tell me about some other cases i can use.
heman0286 Reputable Jul 28, 2014 287 0 4,960 Aug 9, 2014 #2 i dont see any reason.... yes the Asus Radeon R9 280 will fit the Nzxt Lexa S.... link to case site on the right hand side u will see a check compatibility option.... http://www.nzxt.com/product/detail/110-lexa-s-case Upvote 0 Downvote
SlayZombi Honorable Jan 3, 2014 950 1 11,165 Aug 9, 2014 #3 Oh yes, I can tell just by looking at it it will fit. Upvote 0 Downvote
A arceus927 Reputable Aug 9, 2014 2 0 4,510 Aug 9, 2014 #4 heman0286 : i dont see any reason.... yes the Asus Radeon R9 280 will fit the Nzxt Lexa S.... link to case site on the right hand side u will see a check compatibility option.... http://www.nzxt.com/product/detail/110-lexa-s-case Are you sure? Since I read somewhere else that it wouldn't fit. Well I guess it will fit due to the fact that NZXT says so. Upvote 0 Downvote
