Will ATX motherboard fit my case?
Andrej_11
9
Good evening!
After a few years I decided to upgrade my CPU from Haswell to Skylake which means i need a new motherboard. I have a prebuilt PC - HP Pavilion 500 420nc, and i would like to know whether ATX motherboard would fit my case. The original motherboard in the case is uATX.
Here is the link to the motherboard specs: https://support.hp.com/in-en/document/c03885123
My PC case dimensions are : Height: 36.7 cm (14.48 inches)
Width: 17.5 cm (6.91 inches)
Length: 38.9 cm (15.35 inches)
Thanks for any help!
I have already changed the PSU with GPU, and about the cooling i have the side of the case opened and I have good temperatures even with a high gpu/cpu load, so I am not worried about temps as long as I can fit something like evo 212 hyper cooler in it.
Thanmks for the answer tho, you helped me
