M M4nhunt66 Reputable Nov 22, 2014 11 0 4,510 Nov 22, 2014 #1 Case: http://www.coolermaster.com/case/mid-tower/elite-370/ Cooler: http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
Solution draconis123 Nov 22, 2014 The cm hyper evo 212 height is 159 mm. Your case will fit up to 163mm. It should fit fine.
draconis123 Honorable Jan 24, 2014 115 0 10,760 Nov 22, 2014 Solution #2 The cm hyper evo 212 height is 159 mm. Your case will fit up to 163mm. It should fit fine. Upvote 0 Downvote Solution
M M4nhunt66 Reputable Nov 22, 2014 11 0 4,510 Nov 22, 2014 #3 Thank you, I would like to someone else confirming this, just in case Upvote 0 Downvote
