will CM hyper evo 212 fit in my motherboard
kestzro
24
Hello, since I am using mATX ga h61ma d3v motherboard I was wondering will evo 212 cooler fit into it? (I am using 2 ram sticks crucial spectek 1333mhz). Case is fine (210mm).
If your RAM has no heat sinks, the cooler will fit fine. Besides, you can always slide the fan up a bit on the cooler's heat sink to allow for taller RAM.
