will Cooler master hyper 212 evo fit in my case?
JuniorNoyes
Commendable
Nov 10, 2016
13
will Cooler master hyper 212 evo will fit in my DIYPC Zondda-O Black USB 3.0 ATX Mid Tower Gaming Computer Case im about to buy this for my first build setup plz help
how will this cool better if the evo 212 has higher rpm and cfm?
thank you does it matter how close to the window it is or will just look a bit more cramped
From the looks of it it'll look more cramped, that's all. The door will close correctly. Pretty much all tower coolers look slightly cramped, but it's their size that makes it cool better.
The CRYORIG H7, as suggested earlier by Justiceinacan, is actually a good alternative if you want it to look less close to the window, and has very similar thermals. It is more efficient to cool off your PC, but it's by a small margin. The EVO 212 has always done a good job.
so you think i should stick with the vo or go with cryorig this is my first build not exactly sure what to do this is my build http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=36262207
The H7 is actually on sale right now on newegg, so if it saves you a few dollars, go for it? It is sure to fit your casing as well. Both are very good coolers.
Also, I don't see any RAM in your build? Do you have DDR4 RAM already? If not, I suggest you buy some. ^^;
yes i have 18gb or ram but im still not convinced haha saving the few extra bucks doesnt really matter what would you prefer i do haha i just wanna know whats better
thank you so much man appreciate it
