Will cooler master v8 fit in rosewill viper z case
Eyenvu
22
I'm interested in building msi z170 m7 with i7 6700k not sure if the cooler master v8 will fit rosewill viper z case any help would be great
My friend has a Cooler Master v8 GTS in a Cooler Master HAF X case, and it fits, I can't remember by how much, but I remember that we couldn't fit side fan on the case above the CPU given it was such a big cooler.
Looking at the specs and comparing your case, it looks fairly marginal, given the HAF X is bigger. If you are still interested in it, I would advise you to measure the distance between your CPU and your case, and then compare it with the height of the cooler before buying it.
http://www.coolermaster.com/cooling/cpu-air-cooler/v8/
