Will CoolerMaster 212 Evo heatsink fit in a CoolerMaster cm 690 II Advanced
dupras
Hello,
I was wondering if a CoolerMaster 212 Evo heatsink fit in a CoolerMaster cm 690 II Advanced without clearance issues.....I'm looking for a reasonably priced heatsink to OC a i2500k
yes it will, as long as your ram doesn't have rediculous big heatsinks which it probably wont, so almost 100 percent yes. good luck with your build, and the 212 EVO is probably the best as of now for 35 dollars.
Definitely fits. I'm staring at that setup right now :) . The only thing I'd mention... if you were planning on adding any extra fans to the side panel of the case... there's not really enough space OR they'd have to be extremely slim fans.
