Will Corsair H105 fit on the side pannel of the Cougar spike Matx case?
Ocean111
13
I have a cougar spike Matx case that has two 120mm fan slots on the side panel, so theoretically the radiator of the Corsair H105 (which holds two 120mm fans) could fit? Before investing in the cooler, it would be prudent for me to establish if the case (which is not listed on PC parts picke r- but NO Cougar cases are, which leads me to believe they've not tested this brand) can house it.
Thank you oh glorious interweb think tank for help in this Quest-ion
I wasn't thinking straight this morning.
Even if the radiator would fit, it still won't work. There are only two panels which come off on that case. The one behind the motherboard helps cable management, but there is no access to the rest of the case. The only access to the rest of the case is through the panel with the fans. Since the hoses from the radiator connect to the CPU and motherboard, I don't see how you could mount the radiator on the panel and access the system at the same time.
