Will Corsair VS Series VS450 be okay for this build?
Corsair VS is not good quality PSU. Better go with Seasonic S12II or Corsair CXM series.
As for wattage required, pls post full build.
Ok, 450 is enough, even 430 will do. You can go any way want, but if you want to know my opinion, I would rather save on CPU then on PSU. Bad PSU can kill other components which cost way more.
Anyway, few good choices for your build: https://in.pcpartpicker.com/products/compare/FQ648d,TgW9TW,4Vzv6h/
The ones you mentioned are around $250 here.
Please tell me this one will do https://www.mdcomputers.in/index.php?route=product/product&path=68&product_id=2610
the key to a good psu is going with one with either seasonic or super flower internals. will the vs explode on you, no probably not, and it might function perfectly, but when it comes to the component that will power all of your other components theres no reason to cheap out. especially considering excellent psus can be had for little more(depending on were you are).
Yeah well I found a Seasonic one which has 430w continuous supply and 80+ bronze.
