will corsair vs450 be enough for my system?
whatdahil
8
i already bought these some parts and am planning to buy PSU next
intel i3 6100 - bought
zotac gtx 750 ti - bought (will upgrade this in the future but budget is tight now)
msi h110m pro vd- bought
corsair vengeance 2x4gb ddr4 2400 - will buy this after PSU
1tb hdd
wondering if crsair vs450 is enough to handle this coz i know my specs ain't that high
and im also planning on buying the Rakk Phantom X White-Black as my case because it is really cheap.
It's not the best of quality , but for your current system it's perfectly fine and enough power.
Your setup will only run DDR4 2133.
Supports 6th Gen Intel® Core™ / Pentium® / Celeron® processors for LGA 1151 socket
Supports DDR4-2133 Memory
DDR4 Boost: Give your DDR4 memory a performance boost
USB 3.1 Gen1 + SATA 6Gb/s
VGA Armor: Reinforced Armor slot
Click BIOS: Secure and Reliable UEFI BIOS solution
Audio Boost: Reward your ears with studio grade sound quality
Military Class 4: Top Quality & Stability
Guard-Pro: Improved Protection and Power Efficiency
EZ Debug LED: Easiest way to troubleshoot
Overvoltage Protection😛revent Unforeseen Damage
Intel® SBB Support...
Intel® SBB Support: Improves Productivity, Management and Security
WHQL CERTIFIED.WINDOWS 10 READY.
Definitely powerful enough, but doesn't leave much room to upgrade and its a fairly low quality PSU. Just remember that when you get a cheap PSU you're risking EVERYTHING in your computer. I recommend a minimum rating of 80+gold but that's personal preference. many people do just fine on non-rated PSUs, so its up to you.
