Will cpu get bottlenecked
Beno__
13
Iam planning to upgrade my 3 year old pc which has i3 3220 and 230 W power supply with gtx 1050 ti without power connector. Is the power supply enought and will my cpu bottleneck gpu.
your cpu uses 55w, the 1050 ti uses 138 ish watts in the real world. Together that is 193w. Lets say your computer gets warm, with both of those running, plus fans, and your HDD and your motherboard required power, and the lost power due to heat in your power supply, and the cpu or gpu, or even both going into boost mode, you will burn a lot more that 200w constantly, causing a bottleneck.
Hop this helps (sorry if it seems rude, I'm just very direct!)
Thanks for your reply. The problem is iam out of budget and i only want to buy a psu if it is really necessary
