Will Crossfirex tech work with two NVIDIA GPU's?
A7xjk
I just recently bought an ASUS M5a97 r2.0 mobo and am using a EVA GTX 560 Ti. Since my mobo has the crossfire capabilities, I'm wondering if it is possible to simply purchase an additional 560 off of eBay and be able to utilize it in my system. Thanks!
You need an SLI compatible motherboard, the motherboard you have is not SLI compatible so unfortunately you will either be stuck with a single card or you will need to upgrade to an motherboard that supports SLI functionality or alternatively sell your GTX 560 Ti and get two AMD equivalents so that you can benefit from Crossfire.
