Will Cryorig H7 fit in the Thermaltake V1 Mini ITX?
ureagod
Ive researched different results saying people can or cant fit their cpu cooler, can anyone confirm?
Openupitsdave
156
US
the Cryorig H7 is 145mm and the maximum supported height of the case is 140mm so it should not fit....
...but the pics say otherwise..
Does the top of the H7 touch the plastic?
From comments in BrofessorX's completed build in pcpartpicker (the third photo, third link in the post above):
"Added a aftermarket CPU cooler to keep the temps down on the CPU which was the Cryorig H7. The cooler on here was listed not to fit the case that i used. After measuring a few times I discovered i could fit a bigger tower cooler in the system than originally thought."
"I have since swapped out a few things including the cooler(my friend needed a new one), but there wasn't any clearance issues with the Cryorig H7 with the top closing. There was at least 2~3mm clearance with the lid on with the heatsink."
"It does fit! When i had the case i had a tape measure and triple checked before I even ordered it. Didn't even touch the plastic on the top panel. I would upload another picture, but another computer needed the cooler and I sold the rest of it to a friend."
Openupitsdave
156
US
now im wondering how tight the space will be behind the heatsink if I installed 2x 80mm exhaust fans...Would they be touching the heatsink? If that is the case, I would rather find a different cooler..
