Hi, it's been 10+ years since I have build my last desktop and I need some help with my memory choice please.
My setup as follow
MB: X570 Aorus Elite Wi-Fi (DDR 4 3600 (O.C.) supported per MFG website)
CPU: Ryzen 5 2600 (MFG states up to DDR4 2933 supported), this is just to hold me over until the 5000 series supply becomes stable
Memory: S.Skill Ripjaw V 16GB DDR4 3600, CAS latency 19
I picked up this memory primarily because it was on sale, same price as DDR4 3200. The high latency time somewhat bothers me but again I don't plan on doing anything cutting edge. Upon further research I am now uncertain if I should keep this or exchange it for DDR4 3200 with lower latency, mostly because I am uncertain about the compatibility of DDR4 3600 with my MB/CPU combo. Can anyone tell me aside from the high latency, would the current setup work? Is there any benefit or drawback using DDR4 3600 with my MB/CPU combo? Is it just going to run at 2933MHz instead of 3600MHz and still with the slow 19 latency? What actually happens when pairing higher MHz memory with CPU only supporting lower memory MHz? Thanks
My setup as follow
