Will Dell Inspiron 14 7000 work with a 4k Monitor
AlanM
4
Title says it all.
Will a Dell Inspiron 14 7000 work with a 4k Monitor?
Need to buy a monitor for use with this laptop and was wondering if a 4k monitor would be worth while. Looking at a 27".
Will be used for some interior design work so lots of viewing photos.
Thanks
You should post with the specs of your laptop, not just the series.
From this link - https://www.quora.com/Can-Intel-Int...0-output-to-a-4k-monitor-or-will-I-need-a-GPU - I would say yes as long as you have an Intel i5 9th generation processor or higher.
Also, I am assuming that you meant "Does my laptop support 4K on external monitors?" because most chances are it will work even if it isn't 4K. You might have a 4K TV, for example, with signal that is not 4K.
