Will Dual Channel Work?
Ram not in the same kit is not truly identical.
The same part number can be made up of different parts over time.
Most of the time it works, but not 100%.
Less so with ryzen.
What is your plan "B" if the new stick does not work with the old?
1. Do you really need 32gb?
2. If you do need 32gb order a 2 x 16gb kit up front.
3. If you are uncertain, order a 2 x 8gb kit for now.
Unless you are heavily multitasking, have many vm's, or are using ram optimized apps, 16gb is all you will likely need.
Deal with the upgrade issue later.
kanewolf
Buying the "identical" RAM may or may not work. There is no guarantee. The reason RAM is sold in dual channel (or quad channel) sets is because the manufacturer has tested, and guarantees, compatibility between the parts. Nobody can DEFINITELY say that it will or won't work. It is your gamble.
Sep 2, 2018
i am ordering another 16gb stick of the exact same ram, i probably should've mentioned that, my bad aha
kanewolf
And I said "identical" doesn't matter. There is no guarantee. It might work, it might not. You are maximizing the probabilities by buying the same part. But it is still a gamble.
Less so with ryzen.
