Will easyBCD work in safe mode
comicdude319
42
Hi
Basically I am uninstalling Ubuntu without a disc drive on a windows 7 netbook and its my first time doing so. I have another thread open which gave me a method. I am going to use the instructions in this video https://www.youtube.com/watch?v=vt0N2Cpv8CM which require using easyBCD to recreate the windows master boot record since I will no longer be able to boot using Ubuntus booter and select windows. Then I willl delete the Linuxs partitions on my hard drive.
I am wondering if this method will work in Safe Mode of windows 7 starter because I basically cant do anything on windows unless its in safe mode at t moment (unsure why started when I installed Ubuntu).
Thanks
You will need to have EasyBCD already installed, and I doubt you can install it in safe mode.
You should boot Windows install DVD, and select "Repair" from there.
