Will everything work perfectly?
Datcheeta
20
Cpu: intel pentium G4560
Mobo: b250m bazooka
Ram:HyperX 2133 2x4gb
Gpu:Msi gf gtx 1050 ti oc 4gb
HDD:Wd caviar blue 1tb 7.2k rpm
Psu:Corsair TX550M 80+ gold certified
Please if you could reply and tell me what's good and what's bad i would apreciate it.
Yes, as it is, everything is compatible and will work.
If you can find a 2400MHz RAM (which usually is just almost the same price), that would be my only suggestion (note that 2400MHz is the max. speed your CPU/MB can support). The rest looks good - opens up possibilities for future upgrades.
