Curious if this RAM will work with the MOBO and and CPU ?
MOBO:
Number of Memory Slots: 4—288pin
Memory Standard: DDR4 2133
Maximum Memory Supported: 64GB
Channel Supported: Dual Channel
RAM:
Type: DDR4
Speed: PC4-25600 / DDR4 3200 Mhz
Capacity: 2x4GB
Latency: 16-18-18-38
Voltage: 1.35V
CPU:
Intel® Core™ i7-6700K Processor (8M Cache, up to 4.20 GHz)
Socket: FCLGA1151
Cores: 4
Threads: 8
Clock Speed: 4 GHz
Max Turbo Frequency: 4.2 GHz
Intel® Smart Cache: 8 MB
Instruction Set: 64-bit
Instruction Set Extensions: SSE4.1/4.2, AVX 2.0
Lithography: 14 nm
Max TDP: 91 W
Memory Specifications
Max Memory Size (dependent on memory type): 64 GB
Memory Types: DDR4-1866/2133, DDR3L-1333/1600 @ 1.35V
Max # of Memory Channels: 2
Max Memory Bandwidth: 34.1 GB/s
Thank you for answering.
MOBO:
RAM:
Type: DDR4
Capacity: 2x4GB
Voltage: 1.35V
CPU:
Socket: FCLGA1151
Cores: 4
Threads: 8
Clock Speed: 4 GHz
Lithography: 14 nm
Max TDP: 91 W
