Will GAINWARD GeForce GTX 1060 6GB fit in ASUS G10AC-CZ009S ?
Minisvet546
64
I really need to know, i want to change my GTX 760 to GAINWARD GeForce GTX 1060 but im not sure if it will fit im my pre-build PC (ASUS G10AC-CZ009S).
on a prebuilt system it's difficult to find specs on physical aspects inside of the PC case, like the total length available for the GPU to fit inside.
but, we can look up the 760, which is about 12 inches long, the 1060s are around 11-13 depending on your choice of card. So it will probably fit. You could take the side panel off of the PC and just check with a measuring tape from backplate of PC to how far the spacing is free where the card sits to the front of the PC case (from back to front available space, where the GPU sits).
also, in a couple of months the new line of nVidia cards are coming. you might want to wait or not, just letting you know
Thanks !
I think i dont need to wait for new NVIDIA cards cause they will be surelly expensive and i want to buy new GPU now cause they have big pre-christmas sales everywhere now in CZE. Thanks for help, i think i will buy it and if it will not fit, i just refund it.
