Hi,
I have Dell Optiplex 7040 MT desktop PCs with Intel Core I7- 8GB DDR4 2133MHz | 1TB SATA HDD DVD-/+RW and PSU 240 Watts
Will Geforce GTX 750 Ti work with it ?
you asked a question I answered it, yes the card will work on it, with high risk of Psu failure, and I strongly suggest to upgrade the PSU with the video card to at least 300w. the numbers are the numbers I did not make the law of electricity .
technically speaking the answer is yes, but I have a reserve with your 240watt power supply as dell are barely tested over 200w sustained.
< pause for test>
and testing that theory with PCPartPicker.com I see 246watts being in used so your PSU will not be strong enough for this video card
you will need to upgrade that. can you tell if your minitower power supply is of standard size (square box) or an odd formed one?
I have used this 750 Ti with Dell optiplex 9020 MT which has PSU of 290Watts, it works fine...
TBH i have to purchase these Optiplex 7040 MT desktop PCs for a client. Where client has specified both desktop to be 7040 and graphic card to be 750ti
this is what its written on optiplex 7040's data sheet.
Standard 240W PSU Active PFC
240W typical 85% Efficient PSU (80 PLUS Bronze) ENERGY STAR complaint, Active PFC
240W typical 92% Efficient PSU (80 PLUS Platinum); ENERGY STAR complaint, Active PFC
yes 85% of 290w is still 246 wats, 90% if gold would be a little more
but in his case he has a 240watts power supply not a 290w
and 85% of 240w is 204watts
and 92% of 240w is 216 watts
and the consumption of power will be from 76w to 246watts (sustained)
both those numbers your claiming to be in those towers, still would not be sufficient to prevent a burn out of the PSU when under gaming strain
Client require this configuration for their application which has 3d animation they will not be using it for gaming purpose for sure.
Got what i wanted to know.
Thank you for your prompt reply, reply appreciate your help.
