The website specs show 1 8-pin and 4 6+2-pin split connectors so you should be OK.Hi
So I was wondering if gigabyte rtx 3060 ti gaming OC which has 1x8, 1x6 Headers can work with XPG pylon 650w???
The problem is about the connectors nothing else.
Thanks in advance!
That's amazing, thanks sir!The website specs show 1 8-pin and 4 6+2-pin split connectors so you should be OK.
https://www.xpg.com/us/xpg/670?tab=specification
