Will graphics card fit in mini PC? SOLVED
i think it's 8 inches so would be a close fit, do you think it would be worth trying?
What make/ model of gpu, can check exact measurements . 8 inches is 20.3 cm or 203 mm that will fit into 210mm.
Hello slindi70. Yes your old 6850 HD GPU will fit in that case because it will support a VGA card length up to 210mm / 8.3 inches and your card has 198 mm / 7.8 inches. The best of luck!
If the card does not have its 6/8 pin header(s) on the end of the card, it should fit. Which HD 6850 do you have?
ahh, just found it here, http://uk.msi.com/product/graphics-card/R6850_Cyclone_1GD5_Power_EditionOC.html#hero-specification, its a bit to big, thanks for the help though!
