hey everyone, i need help finding out if the msi rtx 2060 gaming z will fit in my gamemax kamikaze pro micro atx case, the motherboard is b450 dsh3 if that matters. i read that the card is very thick so im unsure if it will fit.
okay thanks, the card is 5.2cm(triple slot) my current gpu is 3.5 cm(dual slot) and it has 2.7 cm of space between it and the psu shroud, so for this 2060 model will it be okay with 1.2 cm of clearance for the fans?Yes it will , no problem , case support is:
Maximum Video Card Length
365 mm / 14.37"
