Will graphics card fit into case?
The KFA2 GTX 1070 HOF is ~330mm long. It will fit inside the NZXT Phantom 410 if you remove the upper drive cage (the one with the 4x HDD slots) to increase the total clearance from ~300mm to ~420mm.
Thank you for checking that , i tought when i remove HDD cages it would be 305 mm
