[SOLVED] will GT 1030 work in G41 motherboard?
adilansari689
11
I have Zebronics G41-D3 motherboard. Does GT 1030 Graphic Card is compatible with it?
I was searching on local market for this graphic card and many people are saying GT 1030 won't work on G41 motherboard and i should go with GT 710 or 730.
i am really confused right now whatever should i buy it or not.
keith12
Illustrious
In general terms, the newer G10xx series are not compatible with older mobo's that don't have a UEFI bios. Same for RX4xx/5xx cards from AMD.
The other posters are right. But you could go for a GTX960 2/4gb which are still decent for low-mid level 1080p gaming. A GT710/730 are not worth it and hardly better than integrated gfx.
adilansari689
11
I heard that G10xx series support both UEFI and legacy BIOS.
GTX960 is not available here.
On amazon people are saying GT1030 is working with their motherboard (G41), I also see videos youtube where it's working on G41 motherboard.
My current graphic card GT 610 is died 2 days ago. I don't have any option other than 1030 in that price range.
keith12
Illustrious
Hmmmm. I won't recommend you buy it. It 'may' or may not work. If you update the bios to the latest one for your mobo, it could be okay. But I know that for as many people that say it works there is at least the same that says it doesn't.
I wouldn't waste the money if I wasn't sure it would work.
