Will Gtx 1060 fit in my case?
Matt8741
Commendable
Oct 30, 2016
12
Hi. I am planning to buy the gtx 1060 to upgrade my pc. But I am afraid that gtx 1060 will not fit in my case. Can anyone tell me will it fit in my case or anything that i have to buy in order to upgrade my pc ?
Here is the spec of my pc
Case: cooler master elite 372
Monitor: Dell u2417h
Motherboard: Asus Z-97 Pro
CPU: Core i5-4460
GPU:GTX750 ti
PSU: Cooler Master Elite Power 400W
Ram: 8 gb
SDD:adata sp920 128gb
HDD: Normal 1TB HDD
here is a list of the various 1060 cards with dimensions included. http://www.tomshardware.com/forum/id-3047729/nvidia-geforce-gtx-1000-series-megathread-faq-resources.html#17902600
your case's product page says it "Supports high-end graphics cards up to 315mm / 12.4"" which is pretty much all the 1060 cards. so looks like you're good to go with such an upgrade.
your psu only has a single 6-pin power connection so look the list of models over and be sure you get one that only needs this. some models use an 8-pin connection. all the info is on the link above 😀
Thank a lots. Is 400w psu enough for gtx 1060 or i should to buy a 450W/ more psu?
