Question Will GTX 1660Ti work with DQ77CP Motherboard?
The MOBO is out of support? So, therefore, I don't need to upgrade BIOS?
Depends on when was the last BIOS upgrade they put out in the wild. My girlfriend's Asus P8Z77-V had it's last update around 2013, which I needed to upgrade to the RX-590 I bought for her in... 2017? I can't really remember.
Long story short, if you've never upgraded the BIOS and the GPU just doesn't work, this might be the reason why.
Cheers!
Aug 2, 2018
12
Cheers!
So basically if my BIOS is at the latest version I can buy it and it will work fine and if not I just need to update it and it will work perfectly as well?
